BigMike701
OK, new to off-grid solar so please bear with me. We just purchased a fixer-upper houseboat (basically an RV on pontoons) and it has no shorepower available. It came with (2) 100a solar panels and (4) 12v lead acid batteries, no inverter, and a 3,000w generator, with a 50a charger for the batteries. The 120v only works with generator running and there is no 240v system. I am building a new solar system from scratch. The approximate max demand usage is around 2,800w at any given time (summer running a/c's etc). I would like to be able to run on solar/battery only day and night (generator only for low-sun days). The days in the summer hover around 110*+ during the day and can stay as high as 90*+ at night. Located in Central California.
My system parts so far:
(1) EG4 3kW Off-Grid Inverter (5,000w PV input / 500 VOC / 80a charger);
(6) 450w SunGoldPower Mono Panels (41.72v / 13.82a)(2,700 total watts);
(4) LiTime 12v 200ah (200ah bms) Batteries;
(1) Victron Smart Shunt Battery Monitor;
(AN) 10awg PV wire (from panels to Inverter) The inverter is about 50+ LF away from the array;
(4) 30a MC4 inline fuses;
I feel like I am "under" paneled and/or under storage. I have room for 4 more panels (4,500 total watts) and 4 more batteries (8 total) if needed.
Now for the stupid questions.
1. Would it be better to run the panels in series or parallel or both? The inverter has an 80a charger. Do I need to run higher amps to get higher amp output to charge the batteries or does the inverter take care of that, allowing me to run in series and thus utilize smaller wire?
2. What size Class "T" fuse would I need?
3. Solar disconnect recommendations?
4. What is the max recommended distance (LF) from the batteries to the inverter?
5. What is the max recommended distance (LF) from the inverter to the load center?
Thank you in advance for you advice!
-Mike-
-Mike-
