I want to build a 10-15kw system on a new construction house. With the price of the panels in the pallet quantities approaching $0.25 per watt prices on other components play a major role in the overall cost. I'm just getting started and it is hard for me to account for all necessary parts. What is the final number I should budget for?
The system will be grid-tied and should be ready for the battery backup. I haven't figured the exact architecture yet. I'd prefer to run microinverters, but it seems that an all in one string inverter is the most cost-effective way to add a battery. What do you think is optimal?
Am I likely to run into some hidden regulatory issues? Our guide says:
"Although a licensed master electrician is required to hook up the panels to the electric system, there are no special
certification requirements to install the solar system itself in Maryland" https://energy.maryland.gov/Reports/A Maryland Consumers Guide to Solar.pdf
So it seems like I can do most of the work myself and hire an electrician only to commission the system.
