Complete beginner here but I have done some limited research and I want to make sure I don't make any huge mistakes. I'm trying to keep this project budget-friendly so I have sourced everything used and I have managed to keep it under $1000 so far. The primary goal of the project is to provide enough power to run 2 oscillating fans and a window fan basically 24/7 to help keep the air circulated so that is why I kept the inverter relatively small. The secondary goal is to provide a DC power source to charge other portable battery banks (Ecoflow, etc) which I use quite often in other areas of the house (I will save a lot of money if I can charge them via solar and not wall power).
I already installed six Trinasolar TSM-235PA05 panels in my backyard in a ground-mount south facing configuration. Per panel: VOC 37.1V, ISC 8.31A, PMAX 235W. I already have a Victron 150/60 MPPT charge controller and a 12V 300Ah Lifepo4 battery, and a 12V 400W pure sine inverter. I am waiting on receiving a Victron smart shunt so I can monitor SOC. I am planning on connecting the panels in a 3S2P config which should give me a VOC of 111.3V and ISC of 16.62A so the solar to the MPPT should be fine with 12AWG cables.
It appears that I will need a 30A fuse before the solar hits the MPPT (16.62 * 1.56 = 25.9 rounded up to 30). Do I also need a fuse between any other portions of the setup, and if so, how do I calculate the required size?
Also, I need some help in finding an appropriate solution for getting the solar cables into the house. This system won't be grid tied. I was looking at something like this. I would cut a 1-gang size hole on the inside wall for a low voltage bracket, drill through to the outside, mount the outside MC4 box to the siding (using long screws and caulk to seal it) and feed the 12AWG cables through a faceplate like this. The 30A solar fuse, MPPT, battery, and inverter will be inside of a cabinet with holes/fans for airflow that is secured to the wall so there wouldn't be any risk of anyone yanking the cables coming into the house from the exterior MC4 connectors.
Does this idea for getting the solar cables into the house sound appropriate for the size of the setup or is there any significantly better/safer way of doing it? Please let me know if there are any other suggestions or questions as well.
