JakAHearts
How exactly do hybrid solar power inverters function in the context of being connected to the grid, and what role do they play in terms of grid integration? I hope I'm phrasing this property so bear with me. Say I am making this system but perhaps on a smaller scale - https://www.mobile-solarpower.com/48v-complete-system-blueprint.html. If I connect grid power to the inverters how does this affect the sub panel power? Do the built in MPPT have logic that uses the solar to charges batteries/run load when solar is available but then switches to grid if and when needed? Ive read a good bit and watched even more YouTube videos but oddly have never seen anyone address the exact specifics of how this works.
For reference, Im planning on building a setup similar to above and gradually adding panels/moving loads from the main panel to the solar connected sub-panel over time. Would what I am proposing work and the only extra grid load would be to run the inverters when the batteries are depleted and no solar is available? Or am I completely off base and out of my mind? (wife says yes. That part is true)
