Ranging6880
Hi all,
I did a search and couldn't easily find clarity on this, so apologies if it's already addressed elsewhere.
I am designing a new system, including an inverter with (direct from spec sheet):
Min PPT Voltage: 125 V
Max PPT Voltage: 425 V
DC Startup Voltage: 150 V
DC Shutdown Voltage: 150 V
I only have space for four panels, and likely not behemoths. There will initially be between 1 and 3 Pylontech US5000 batteries associated with the system (4800 Wh, Depth of discharge: 95%, 48V)
What is the relationship between Vmin/mp/oc, Min PPT voltage, and DC Startup voltage? I'm trying to ensure I install an array that can always (bar night) produce enough DC voltage to start the inverter, or if that's not possible given the constraint on panel number and size, designing the array such that I understand when (times of day and year) the array is likely to be non-functional.
Happy to add an additional MPPT direct into the BMS if that solves the issue. Any guidance much appreciated
