dricket
I'm looking for ~30 kWh backup via an LFP battery with 10+ kW of continuous power for my newly all-electric house, with about 20 kW of solar to be added this spring.
I like Homegrid because it sits on the ground, vs. hanging 1000 lbs of Enphase batteries on the exterior wall of my house. The house was built in the 1950s, wood frame, single story, in fine condition, but I'm in California and so I want to plan for an eventual large earthquake, and I would feel stupid for making my house collapse due to that weight.
On the other hand, I like the Enphase battery because I'm more certain it will work with the enphase microinverters. I found this thread where homegrid+sol-ark is not charging from solar during an outage:
And I really don't want to mess around with firmware, I just want the system to work 100% reliably.
So I'm stuck deciding between reliability of enphase vs. ground-mount stability of homegrid.
I've also looked at Panasonic's LFP battery, but I'm not sure if they're actually shipping.
Any tips would be very much appreciated!
Thanks.
Sol-Ark 15k inverter AC coupled with Enphase IQ8+ grid tie setup not producing solar off grid
I work for a company that has installed a number of systems in the following configuration: grid tie residential system using a Sol-Ark 15K limitless inverter, with a Homegrid Battery (size varies site to site), and an AC coupled enphase IQ8+ microinverter solar system. The systems all work fine...
diysolarforum.com
Thanks.
