Water heating with solar
Not exactly "dedicated", as it's a secondary use case, but I have 4x 300w panels 2s2p (about 70 vdc) that I use to run my solar direct well pump through its controller. It doesn't take much energy to keep that low producing well pumped dry, so I have excess solar available from that array...
I have a 110vac receptacle, that I can switch from the pump to the receptacle in a breaker box, wired directly to the pv panel output, so 70vdc at the receptacle. I have a 5 gal single element water heater that I sometimes run off that array. (I can't remember if I used a 1000w 48v or 110v element, but I think 110v as I can also just plug that WH into the grid.) When the sun is good, the water heats up in a few hours. The WH has a standard WH thermostat, so it shuts off at the set temp.
Got it. You have a "Fun project" for already dedicated solar panels. OTOH the OP asked:
Hello, I currently have excess solar capacity (3.2kw) and I am wondering if anyone has experience using a dedicated water heater powered directly by dedicated solar panels. My option would be to use a 24 or 48v heating element and connect directly to a single inverter. Maybe a bad idea, but I wanted to check ,.. I have the ability to use a propane on demand heater as a backup. Any thoughts are appreciated ... Thx
So, ... "Excess solar" apparently some "extra" panels laying around. IMNSHO I'd buy more AIO before I'd cobble something together to heat water. An awful lot of effort to dedicate panels for a relatively small load. Hooking the same panels to a small $500 AIO would be more expensive but vastly more useful. An even better solution would be to scale up the existing system with more inverter/mppt/panels, then use the excess wherever you want albeit with some conversion losses.
I mean is it free to retrofit heating elements and control mechs to connect a HWH to a bunch of solar panels you have laying around? Without knowing what is existing, again tossing the panels onto another parallel AIO, or MPPT, increasing the battery and scheduling HWH is more flexible.
I think you made my point, you already spent a lot of money. This discussion is not applicable to you. Everyone sees things as how they relate to their own situation. Somebody wants to get rid of 3KW of power instantly. That is just not easy or cheap to do. HPWH only use about 600W of power and run a long time. It takes batteries and inverters to run them. I have this guy up in Michigan with 600W of panels and a 100AH lithium battery. Now he has hot water and he heats a cabinet in the winter where it is stored. No expansion needed in his system.
I heat 2 50 gallon electric water headers (in series) with my excess PV power AFTER my battery is full
I heat them to 125deg F and it usually is complete by 2-3pm
I use 3000 watt 240v coils in both, upper and lower heaters. All cascaded
here are the 2 links in my build thread
theory
implementation
works great, very little nat gas is used in the summer in the tankless water heater - majority of the water coming in is higher than the tankless is set for
I also have dial mixing valve to ensure the water is not too hot going to the facuets
Watched the video, pretty awesome!
It appears you're confused on the theory and your approach is very inefficient. The power is always available, its just takes what is not consumed in the moment (ie., no loads, batteries charged).
There are losses in the charge controller, the inverter and what do you do when you don't have more battery storage? Also, power transmission is efficient at high voltage -- most inverters/controllers max out at 48V and power is P = VI or P=I2R.
But it's already 100% wasted energy. Who cares if you get 3% or 83% of that back?
I will politely offer that it appears that you are the confused one. Energy that is put to no use has 0% efficiency. Feel free to derive that calculation if you want but it won't survive any sort of inspection.
OP has an array that is doing nothing for them, ALL of that energy is being wasted. Do all the math you want but once zero's show up it doesn't matter how cool your formula is, bad things happen to the overall results.
Installing an electric water heater to preheat the water is simple and reliable. Over complicating things and berating others for not going for your definition of perfect is counterproductive.
Here is the basic theory. Let's start at the panel current vs. voltage curve. The maximum powerpoint is when the voltage is highest and current is highest. With no load on panel, the voltage goes torward open circuit voltage. When a load current is applied, the voltage drops. A good assumption is that when panel voltage is above maximum power point voltage (Vmp) there is excess solar to be harvested.
This is how the circuit works: it monitors the panel voltage and when it goes above Vmp it turns on the heating elements. If the solar charger is also trying to get some energy the panel voltage will drop below Vmp and the heating element turns off and the charge controller uses MPPT to find the optimal power point. The heating element circuit is just responding to solar availability and current charge controller consumption. Of course the chosen voltage to toggle the heating element is going to be a little dynamic because of panel temperature coefficient, etc. A toggle voltage slightly above Vmp seems to work well for me.
View attachment 230885View attachment 230886
I designed my version to handle my panels (above Victron VRM screenshot) which operate at a Vmp of ~168V. I am running two 220V x 3500W heater elements in parallel. The resistance of the each element is ~15.4ohm or ~8ohms total in parallel. At 168V that is putting through ~21 amps and 3500W of heating power. I will be using this to heat a cypress hot tub in southern Chilean Patagonia (currently in testing in the US).
I chose this design to not cycle by LiFePO4 battery bank (no water heater power goes through the charge controller or the inverter). Also as @efficientPV points out you get the efficiency from the high voltage. 48V heating elements are totally useless.
I have 4000W of solar panels, a Victron MPPT Solar Charger (250/100), Cerbo GX and REC BMS connected to a 15kW battery bank (48v). We have so much solar in summer that we use an electric oven with no problems.
wrong post
I promote good design in heating water. I'm not limited t promoting any one circuit. Looking at PV array voltage is a good way to determining when excess power is available. Diverting from the array is efficient and cost effective. This method is very cheap and avoids using the resources of charge controller, inverter and battery. Nobody thinks they do, but every successful solar system has excess power which is free for the taking. This is a picture of my camp from the south, see any solar panels? I run a camp and heat water with the excess. I have three water tanks and one is just for laundry. All cycles use hot water. If you can't heat water, "Don't blame Desenex."
Here is a shot I took this morning, it is totally overcast and will rain today. Everyone is impressed with big numbers. Look at all those YT videos of the "bucket people", they stick an element in a bucket and connect it to a panel. It is bright and sunny and everything works fine. They never show you the rest of the day when it drops to nothing when the mismatch kills the power. They have no idea that the power is a function of the square of the current. I find this shot impressive, you probably won't.
View attachment 230880I run three water heaters and they all can be operating at the same time. Each has a set priority based on voltage. I test my board at 30A and it has half the capacitors. The board shown I think he will be trying 4KW. I designed a microprocessor for a guy in Canada that had a converted oil tank with five elements. Four were switched in and one had variable power. Dacian "matrix man" and I can't think of the board has a switched element system to match the array. Great idea, just about impossible to implement because factory heating elements don't exist in the values needed or your tank only has two. This is where a proportional system works out better.
OK you have my attention.
This looks like what I was shopping for two years ago but could not find a designer for. I put out requests for RFQ's to multiple places online for people who "prototype circuits" offering to pay for prototype boards that would do something similar (i had requested a temp circuit w/NPT to shut off if temp exceeded xx.xx for safety purposes). all i got back were people telling me if I gave them a circuit design, they could build it...that's not what I put the RFQ for!
I gave up looking for a digital controlled DC answer and settled on keeping it all AC where I could build the circuit with relays and standard temp sensors using the built in controls/circuits when available for the inverters and whatnot.
I'd like to use this video to illustrate the issues with matching a PV array to a heating element. This off grid system tries a number of methods to heat water and is still struggling to meet his needs.
@11:07 his open circuit array voltage is 281V. Power point voltage of that array at his temperature will be about 281 X 75% = 210V.
@16:12 the element voltage has dropped the array voltage to 41.7V with a current of 3.035A or about 130W. I consider getting 3A out of a high voltage array still pretty good. With a power point controller the power would be about 210V X 3A = 630W. That is almost a five times increase in power.
In my garage I have a manual transfer switch to change my array from parallel to serial doubling the voltage. This allows me to run that high voltage into my inverter directly to the high voltage section and run the washer right off solar panels. From watching, his system is very manual hands on. By adding a manual transfer switch to go from serial to parallel, the current would double to 6A and voltage to 84V resulting in the heating element producing 500W. That is a big power increase for little effort and this could be automated.
1000023538.jpg I made one using a RPiPicoW (because it has two cores). One core processed the voltage from the batteries. If the voltage is above 51.6v then it allows more % AC power through using a Triac. The reading here shows the temperature. Every three seconds it will alternate to show the %power of the 3kw total. Because it uses a triac to allow very small changes in power usage it tracks the excess solar really nicely. I might upload more info if anyone is interested.
That adds new meaning to the term boom box.
How does the inverter like the TRIAC. I saw one commercial diverter that would rectify the AC on one side and PWM the sinewave. It was designed for use with PV inverters to give a better load. They must have done that for some reason. I only do PWM DC diversion. I don't know what it is like to have an inverter.
Inverter has no issue with it so it seems . I included a snubber circuit and it has no noise. I was curious about that myself. I also have induction hobs and I was wondering how the inverter would cope with the power factor because it is quite noisy. Inverter copes fine. I've attached the graph from today and a bit of yesterday. I'm away from home so the only use is the immersion. You can see it utilises the solar well (until it heats up of course and the solar goes unused).
I have built a circuit (based on the design of @efficientPV) that heats water directly from my 4kW (4s2p) solar panels (2 heating elements 220v x 3500W). It sucks the energy right from the panels and never makes it past the SCC and thus never cycles the batteries. It was relatively cheap to manufacture (like 50USD all in). It uses a version of power point (i.e., turns on when the voltage of solar panels is above Vmp) that just uses whatever current available until voltage drops below Vmp. I have it wired in parallel with my Victron SmartSolar controller -- its been running for a week and works great. It's designed to handle upwards of 30 amps at 170V DC.
Here is a picture -- I can provide circuit diagram to whoever wants it. I suggest watching @efficientPV videos on Youtube to get a better idea of how this works -- its quite ingenious as it doesn't use a microcontroller (just analog electrical components -- ressitors, capacitors, MOSFETs, etc).
I just got twenty IR2153 from ebay, they were cheap at less than $10. Immediately tested them to see if they were fake and not do the correct shutdown. Good news was 11 were real. 9 would not oscillate at all and were totally dead. Still a decent deal for 11 of them. Most want a couple bucks each. I have had a number of fakes, never had one that wouldn't work before. This is the reason I hesitate recommending this design because they absolutely need to be tested.
Hi
The values given in your schematic dont seem to balance.
For example, you have a string of 4 x 2k5 resistors in series with Vin at 168V. This results in a voltage drop across each resistor of 42V, resulting in 0V output at the bottom of R4.
Also, current tops out at about 16mA, not 28mA as suggested.
Has this schematic design resulted in a correctly functioning pcb?
Thanks
Hi
Could you explain please the function of the thermo switch terminal on the schematic and photo.
Thank you
Schematics are never correct.
D4 is not needed, just jumper 1 to 8
Only one 10K pulldown is needed on each output of the 2153
R29 should be limited to 1K or use a LED and some resistor. Turn off is at 1/6 Vcc Getting the voltage lower will increase reset delay.
You can drive with LO only if zener is placed across C3 to limit voltage to 1/2 Vcc. This prevents alternating outputs. LO has priority.
16-20ma is the target. Resistor power dropping has highest immunity surge pulses. A 12V switching supply eliminates all the calculations but has less immunity.
Believe thermo is the precharge resistor at capacitor bank. Thermostat can be placed here if Delta of Voc and Vmpp is less than 30V. This is just a simple shunt regulator. When open, capacitor bank goes to preset voltage.
When used with CC, Diode must isolate capacitor bank from array.
Hello, I'm new to the forum. Water heating with the help of photovoltaic panels seems very attractive to me. I myself decided on a system with 4 panels (in series) Trina Vertex S+ 450W (NEG9r.28). I will also add an ACTii AC7391 and a 230V 3kW heater. If I calculated correctly, the optimal heater is 17.68 ohm, and the 3kW has a slightly lower resistance (17.63 ohm). If the system works well, I will add another one next season. Since you have a lot of experience with such systems on this forum, I am interested in your opinion about my problem. I will appreciate any comments.
There is practically no experience here with these systems. Everyone is direct connect to element or run off system inverter. I do design these systems and use them as a diverter for excess power from panels that are connected to a charge controller. This works quite well for arrays that have a natural power point. I hope you can clear up some confusion in the manual. Can the minimum voltage be set which prevents the controller from seeking a lower voltage? This would allow this to act as a diverter also. The newer version does not seem to include this setting. Heating elements are not that accurate and generally run higher. That is not a true MPPT when used with fixed resistance. The resistance would have to half the ideal to account for array voltage drop due to shading. Your device would not tolerate a lower resistance due to limited capacitor bank This heating is based on RC time constant of capacitor and load. The higher the resistance, the better it operates. For average daily output the ideal resistance can likely be 50% higher without a loss.
Hello, thanks for your reply. I admit that I am a little confused about this inverter (ACTii AC7391). If it is not actually MTTP, what role does it play? The calculator on their site also calculates the above resistance for me. I have a 1500l storage tank and I will use this system exclusively to heat this water. No batteries and completely separate from the mains. I found this inverter today while browsing the internet: https://www.tme.eu/Document/8a81b7d3d9c48bcfdaef4f502a588b0c/MPPT-3000_EN.pdf
You misunderstood the role of the fixed resistance. The MPPT function works fine for normal light intensity changes. It does not work for complete shading of one or two panels in a series. For example, three panels in series producing 100V at 10A. That would be 1,000W into a 10 ohm resistor.
If one panel is totally shaded and goes into bypass, that is now 66V capable of 10A for 660W. Problem is the resistor is still 10 ohms and all it can draw from the panel is 6.6A. That works out to 436W. This is an over simplification. With typical MPPT charge controllers, array voltage can drop with shading because that voltage will still be higher than the battery. Don't heat water with panels that get shaded, it won't work well unless the resistance is lower than ideal . Your unit is not designed for best performance with lower than ideal resistance. Most of these units are high frequency to reduce cost and size. They require external thermal sensors. I took a different approach and went low frequency (50Hz) with an arc interrupt off period. That makes them larger and more expensive to manufacture. Factory mechanical thermostats can be used and daisy chained to multiple elements. My units can be used stand alone with thermal panel tracking. They are designed for diversion at a fixed voltage above power point.
I previously removed a 4KW element in my hot water cylinder with a 800W element, the reasoning behind this was that even cloudy day I could at least heat the hot water and run the house and not really pay for electricity.
I took this to the next level after installing a three phase power monitoring system (IAMMeter) on my single phase home, then using home assistant auto switched the hot water on and off using a sonoff switch at 1 second resolution based on load and generation not importing from the grid.
IAMMeter then created an ESP home hot water linear controller, which can adjust the power being fed into the hot water element based on the solar generation and not importing from the grid. I was one of the users that trialled the engineering prototype. It works great, I put a 2.4KW element in my hot water cylinder because now the system can consume all the excess generation to heat the hot water. Works awesome. It was called the SCR-485 after the resistive controller used.
They have now gone into production with the WPC3700.
Thank you for your reply. Considering that it is a fairly small area (4 panels) and that there are no trees in the area, all 4 panels will actually work with approximately the same power. Is your system also commercially available? Have you ever compared the efficiency of DC systems with those that convert DC to AC (such as micro inverters)?
These systems are very common in Europe, quite a few made in Poland. They should run about 94% efficient. I only provide information on how to build them. Almost all commercial designs are stand alone. My designs are for diversion from panels that feed charge controllers, although they can operate independently. Just how would you get microinverters to work? My heating systems are only suitable for those with advanced technical skills.
For some reason there is a lot more direct from PV water heater controllers in countries outside the USA such as Australia. Not sure why there still isn't a simple plug and play system for PV water heaters in USA. I gave up and currently hooked it up as a regular load to EG4 18kPV which provides me with enough power even when water heater kicks on (4500W/240V AC). This was simplest solution for someone to understand since everything is exactly the same as water heater that is grid powered.
That is exactly what I did too.. sadly I only have a 6kxp so I have to tell the wife not to power anything else when the water heater is on.
Have you though about switching to a lower wattage element?
Of course 1/2 the wattage = 2x the amount of time to recover but for most that wouldn't be an issue but the same total energy.
