I am a planning to run 80’ to two inputs of a Bluettie AC300…from 6 460w panels…3 panels on each input for 1200w, 13a, 124v total VOC. The panels are 41v VOC each.
I understand gauge calculations, etc.
But what I am not sure about is the weak leak UP stream of the current.
The leads going into the AC300 are only 14 gauge.
Do I need to be concerned about power loss? Over heating?
I have ordered 10g wire for the 80’ runs. But is that even necessary if the leads for the input going into the unit are only 14g? I understand it is ok if each panel has 12g lead wires from the junction box, but to go from 12g from the panels, to 10g for the 80’ run, just to go the last 3’ at 14g seems problematic.
Thoughts?
Do I need to replace the leads with more robust home made wires?
Thanks!!
Thoughts?
Thanks!!
