Stupid Monkey
- Dec 14, 2019
- 193
So, I'm in the UK and run MTB events, actually the most popular enduro series in the UK. This means from Feb-October each year I'm 80% of the time away from home, in my campervan. I run 7 events at 6 different venues roughly 1 per month from late March onwards. I've admin (laptop/internet) work to do everyday and stints building MTB trails "on site". Rather than commute me and my dog just live in the truck and have a more relaxed life (no wife/kids to think about).
So as well as the "normal" RV loads that my current setup supplies including heating a 50L hot water tank on dump load I'd also like to run the entire event from solar/inverter rather than use a generator. This is as much for marketing as "environmentally good" as for saving money. But its also safer, with topping up a hot generator with petrol scores very high on my risk assessment. I've other enviro things happening for 2020, including plastic reduction.
At the 2-day events the timing kit (3 laptops, 3 TV's) arent a big load, neither is the PA system, but I also have the "Bar and Bean" serving drinks coffee/beers etc all day (14 hours), coffee machine is 1500w, gas urn for hot water for tea/hot choc, and running a couple of chest freezers as fridges (better insulation) for the cold drinks/milk
Hence the ~11.5 kw/hr bunch of cells to run all this.
I'm hoping that I'll also be able to ditch the generator for my daily food cooking (I do like my halogen oven) or at least from later in the year, maybe not in feb/march when there isnt a lot of sun, but we'll see.
I have room to have 3x the Solar I have (750w) but after reading about how Lithium doesn't like to float all the time I'm sticking with the 2 panels i have now to start with. That should be 3kw/hrs a day, 1 for the fridge/freezer in the RV, 1 for the oven and 1 for everything else & hot-water tank heating for shower.
The 7500kg camper (16,500lbs) also has 50L hot water tank heated by 300w 12v heater on dump load, and I've also ordered a small counter-top dishwasher and small (boat) washing machine, and a domestic 50/50 split fridge freezer.
If anyone thinks I'll end up needing more solar then shout, its easy enough for me to add panels, I could even add 2-4 vertical mounting on the side for winter use if I wanted. I read that you should angle panels to the same degree as latitude, and I'm between 52 and 54 over the 6 venues, so that's closer to 90 (vertical) than horizontal although if you adjust for mid-summer sun at 23.5 lattitude then the effective angle is 30 - and best on the roof horizontal.
I change my mind every hour on putting extra panels on or not ..... but if in Feb i end up running the genny for an hour at night to cook my food, at least my 30A mains charger (victron) can also pump power in
March's event, as well as 1 of the 2 October events have mains electric - not any van-life i have at the venue building before, but its mainly the march/june and August events that are the 3 big ones with lots of work to do beforehand where I'm on site for 6-8 weeks each
Pics for .... well, give you an idea.
My 2019 events you tube playlist, 30mins, if interested https://www.youtube.com/playlist?list=PLp_0utnQ9y8QXNai0S-1v2b_cAGVSW0iu - or just watch round 2 if just 1 round/5 mins
