I don't know if I've seen manual for the PC software from JBD. I wish JBD would update the software so it translates to English better. Is there some reason you are using V1.B? Mine is 2.9 I think.
A lot of the settings will have to do with your cells and preferences.
The picture you attached is Start voltage where the cell voltage needs to be at or above before it even starts balancing. Accuracy is how closely it will try to keep cells together.
The one below it is actually translated better on my PC, and it says GPS Off voltage and gps Off time. I don't know what those do, but I didn't change them.
With top balanced cells, I have my balance set to start balancing just as it begins to reach the upper knee where cells start to separate and have it set to 20mv accuracy. I found this start number by just watching the cell voltages on the jbd app as it was charging.
Most important to get set right is in the "basic protection parameter configuration".
Is there something in particular you're trying to figure out?
