I just got a Chins 100Ah battery at Walmart. Have 90 days return window. How to test it to make sure it is good and reliable? Have a Renogy current shunt, volt meter, clamp on amp meter, 10A LI battery charger but that is about it. Oh, have a 100A Harbor Freight battery tester. I use the LI charger to charge the battery to 100%. Used a camper fridge pulling 10.3A load to run the battery down to a few percent in a little over 9.5 hrs. So capacity is ok at about 97ah before I stopped it. Now doing 80% to 20% tests. Run the fridge from 80% to 20%, then use the 10A charger to charge back to 80%. Repeat a few times.
How long to do this? Days ?Weeks?
Better tests to do?
If it is good now, nothing to worry about?
Heavier load tests? 50A draw? 100A draw? Don't have anything that will pull those kinds of loads. I have a lead acid Harbor Freight 100A heating element type tester that can do big loads, but you have to keep your finger on the switch and you can't leave it on for very long. Minutes ok, hrs, no.
Run battery down to where the BMS shuts it off? and repeat a few times?
If theses batteries fail, do they fail right away or months/weeks later? (if at all)?
Just have 90 days and did not want to buy 100's of dollars worth of test equipment to say that a $250 battery is ok.
Better tests to do?
