I have 16x 280ah REPT cells wired 8S2P with 2x 200a JK BMS, one on each 8S but they are constantly throwing up wrong data.
For instance, I'm getting Battery Fully Charged message and it's showing 100% when the voltage is showing 27.4v. I also know its not fully charged because this morning the batteries were showing 50% and the solar has only put in 6kw today into a 15kwh battery pack.
But if I go to settings and change the battery capacity to say 200ah then change it back to 280ah it drops from 100% to a more realistic 79% and allows more power.
Are these cheap JK BMS useless? Or is 27.4v actually full?
I've attached some images for reference.
