I've installed 8 x 600W panels on my roof and a Powmr 6.5 kW hybrid inverter along with 10 kWH of lithium 48v batteries in a storage room of my small concrete off-grid house.
Everything is working great, but the noise from the inverter's fans when there is even a tiny load is extremely annoying and can be heard from anywhere in and around the house. The storage room currently has no ventilation and the weather is often 30-40c outside, so it gets pretty toasty in there.
Any suggestions?
Some ideas I've had, but not really happy about any of them:
1. Replace the 60mm inverter fans with something quieter (might still be too loud and/or not strong enough)
2. Remove the inverter's fans and rig up some kind of large external fans ducted into the inverter.
2. Add some vents to the room, possibly with fan(s).
3. Add a small air conditioner to the room (seems counterproductive to add extra noise and power use).
4. Build a shed for the inverters and batteries 50m away from the house down a hill (a lot of work and would require extending the PV cables 4x further)
5. Buy a much more expensive, passively cooled inverter (would probably still need better room ventilation).
Any suggestions?
