fluffball
- Jul 4, 2022
- 7
When I connect my battery bank to a new AIO, the battery bank loses its voltage. I can charge it back up within seconds so it hasn’t been discharged, just doesn’t show a measurable voltage across its terminals.
I can watch the battery monitor as the voltage goes from 55 to zero in about 30 seconds.
The bank consists of 4 SOK 12v206ah in series. I balanced them and they have passed my tests for capacity (10.5kwh) and can power a 1kW load with just two in series (I tried several combos of just two with a backup 24v inverter).
Could the AIO be shorting the battery bank and the battery bank BMSs are protecting against massive current flow causing this behavior?
If the BMSs behave as such then the AIO is likely faulty, not the battery bank.
