Aridom82
Learning addict
Hi i finally got my system up and running. 3x Voltronic Max Axpert 8kw generating 3 phase power.
However when the system is running from solar/battery (sbu mode) i still see in the main panel watt meter a constant 0,13 kw being draw from the grid.
Are the inverters consuming this power? And if so, is there a way to reduce or fix this?
Thanks
Thanks
