I buy tinned wire from marine suppliers. The Chinese approach is look at something ,copy it but try to use cheaper materials and design then sell it just under the previous price .
Have you noticed how your feet have been growing in chinese shoe terms over the years ? Each size gets a bit smaller each year.
Thank youI buy Spartan Power cables. They are made in the USA (assuming you are too based on your username), and are top quality.
I went to the company's website. You can buy different lengths, lug sizes, etc. Thanks! Anything to not use Amazon.I buy Spartan Power cables. They are made in the USA (assuming you are too based on your username), and are top quality.
The terminal end in that picture is a TERRIBLE cheapo acid or moisture environment fail waiting to happen...I buy Spartan Power cables. They are made in the USA (assuming you are too based on your username), and are top quality.
The end of the terminal is open... so, unless the wire is tinned, acid or salt can degrade the wire.Dang, really? They advertise as heavily tinned copper. Isn't that what you want?
As long as not near acid or saltwater, they will be fine.I spent some bucks on 4/0 from them. I'll have to examine that when I get home. Another day, another pile of dollars wasted on crap...
Maybe seal the ends with grease?
FYI, ^^that^^ Amazon link is our listing, those are all sold by us (we're Mobile Power Pros and Bay Marine Supply on Amazon), so if you want those FTZ lugs and/or marine-grade wire without using Amazon, you can order the same components directly from our web site.
I had links already from JeepHammer for lugs, I don't need any links thanksI just found these lugs thanks to @JeepHammer. I'll be using these from now on:
Non-Amazon link for Santa:
I think once you guys start to solder your closed ended terminal, you won't look back! Been building cables that way for years. They run much cooler with the huge conductivity improvement.
What would you call "normal" solder?Just note that cables soldered with normal DIY solder used outdoors deteriorate VERY quickly.
Silver solder is the solution here I believe.
To be honest I just crimp most often now and cover with glue backed shrink tubing.
