I bought the EG4 18Kpv and 6 LifePower4 batteries to have backup power if the grid goes down. My existing grid-tied solar system is AC coupled to the new inverter, and the entire system is set up with my utility for exporting back to the grid. I want the full 100% of battery capacity to be available when the grid goes down, so the system can last as long as possible before the batteries are drained.
Here's the problem (unnecessary limitation?) with the 18Kpv that I've run into. The new inverter insists on draining 10% of my battery capacity as soon as the sun goes down, and the batteries remain at 90% SOC till about 10AM the next morning; when there MAY be enough solar power to start charging the batteries back close to 100%. If the grid goes down overnight I am starting out 10% behind in battery capacity. There is no setting to tell the system to LEAVE MY BATTERIES ALONE while the grid is up. Why not?
This seems to be well within the technical capabilities of such a powerful and clever inverter, but the software programmers didn't think anyone would want this, I guess. Is there some valid technical reason for needing to discharge the battery bank every day? Does anyone out there have a way around this?
I have tried to use the Quick Charge feature to work around this limitation, but Quick Charge isn't working on my system. I would guess that it is seeing the same 90% limitation on AC Charging. The funny thing is, on my laptop hitting the Quick Charge button brings up a dialog box that says the action was "Successful", even though there's no battery charging going on. That's another small issue. There are inconsistencies between each of the available monitoring and settings panels in how they respond to user inputs. It just adds to the confusion. I can live with these inconsistencies, but I don't want to live with less than 100% battery capacity when the grid goes down.
I have contacted Signature Solar about this and they say that this is a limitation that they've discussed with EG4, with no solution available at this time. I imagine that this would require a software change from EG4 or LuxPower to accomplish what I want. I sent an email to EG4 on their website, but haven't heard any response yet from them in 4 days. I'm going to send them another message in case they just missed my first one.
Is there anyone from LuxPower lurking on this site who could comment on this issue?
