SiliconOrb
- May 31, 2021
- 13
I've seen some hate for Eco-Worthy kits, and really don't understand it.
Maybe if you are buying everything with batteries, expecting a turn-key solution, they may not be so great. But I purchased the basic Eco-Worthy 24v 2400w kit a month and a half ago, just to get the size and quantity of panels I needed (very important for my installation), the panel wiring and the junction box. Everything was shipped quickly and arrived undamaged. The price wasn't too bad either.
The panels seem to be performing fine in 2S6P, the junction box does generate a bit of heat when the sun is really pounding the panels, due to the smaller than ideal internal wiring, but the fuses, diodes and breakers are sized appropriately and the box seems decent enough so long as it's not directly exposed to the elements and the terminals are checked for tightness. The provided controller is a cheapy which I had no intention of using, so it went into my parts box or a possible future mobile setup. Instead, I paired the panels with a Growatt 3000w all-in-one and a couple of low-temp 300ah CHINS Smart batteries. So far, I've been able to use about 150kwh from the system, with little to no issues.
The panels seem pretty sturdy, and I have even walked on them gingerly, being careful to step only on the frame areas supported by the mounting brackets. I think my peak output from the panels has been in the neighborhood of just over 1600-1700w , but my panels are mounted on an existing shed, with less than ideal angles to the sun.
I'm sure that there are better and/or cheaper ways to go about things, but for a neophyte, it was nice having most of the essential parts included to at least get to the point of an output from the panels. No regrets so far.
But my question is, what am I missing about these kits that raises the ire of some folks? I'm genuinely curious about what I should be looking out for in the way of issues.
