Wiese 100 amp 12 volt Batteries 4 in parallel but want to use 6?
James Tosh
I want to upgrade my system in my 5th wheel and use 6 Weize 12v 100 amp batteries in parallel , they only recommend only doing 4 batteries in parallel. What can I do to achieve this?
Can you post a link to the doco that says no more than 4 in parallel?
Usually these types of batteries are limited to no more than 4 is series.
to parallel 6 batteries I would use the posts method as explained in
section 3.3 Parallel battery bank wiring of https://www.victronenergy.com/upload/documents/Wiring-Unlimited-EN.pdf
If you want 600Ah then it might be better to get 200Ah (or even higher) batteries. Then you only need 3 (or less) instead of 6.
The user manual I got with my Weize 200ah batteries states 4 in series, but up to 10 in parallel. However the label on the battery says 4 and 4. They respond to emails fairly quickly, see what they say about the discrepancy.
