tekno_boy
- Oct 23, 2022
- 3
I am about to start my first solar project. My own roof.
It goes like this. I live in Spain and get a LOT of sun. The sun travels directly over my roof from one side to the other. It is just a Tin roof with spray on insulation and I was simply going to cover the roof in new roofing (call "sandwich" here because it is insulation sandwiched between two tin layers with roofing tile effect one side).
Then I thought, why not cover my entire roof in Solar panels, it's only marginally more expensive!
The House is 13m x 7m and the angle of the roof is very slight (about 15 degrees).
I know increasing the angle of the panels will increase efficiency, but I'm not too bothered because I will be installing 91m2 of solar (I will do the whole roof for aesthetic reasons).
Given the solar panels are more efficient at a certain angle (depending on season), Here is my question:
Does generating more power because of an optimal angle speed up the loss of efficiency cased by aging?
Put another way: If a lower angle produces a little less power, will it also reduce in efficiency slower from aging?
Basically, I live in a windy area and my roof is quite flat at only about 15 degrees. I would rater not angle the panels and I want to know if that means because they are less efficient, they will in fact less efficiency slower? Like I say, with that much coverage in Spain I am not worried about getting the most power as I will have definitely way more than I need. So I only need know if I lay the sown right on top of the roof, will their efficiency loss over time be reduced because they are at a flatter angle?
It's a very interesting question and one I have not seen anywhere, hence coming here.
Thanks in advance for any insight you might have!
