pralinebuckets
- Jan 3, 2021
- 59
Hi all,
I have an off grid cabin and built a small solar system with mainly things I had from other projects or was able to get off of friends. It isn't working great, so I'm trying to think of ideas for how to cheaply make it better. Current system:
4x 6v Trojan FLA golf cart batteries in series for 24v
1x 2000w 24v to 120v inverter
2x 100w Renogy 12v solar panels in series
1x Renogy 20A PWM (voyager) charge controller
The area doesn't get a ton of full sun, so isn't reliably charging the batteries. I've been looking at whether an MPPT charge controller might boost the efficiency, but am worried that because I'm supplying a 24v system with roughly 24v (+/-), I'll still be limited by the panels not supplying enough voltage to the charge controller to really do much good. Is that a good assumption? And if I changed the batteries to be 12v with the same solar series setup, could I expect any more performance with the rest of the setup the same (inverter voltage requirements aside..).
