sonjasolar
- Dec 13, 2022
- 3
I purchased a property with an old solar set-up. It had a trickle of working power and has since died. The current system has 6 panels in parallel at 310 W and 46.1 open circuit voltage. (see image below). The batteries in place have died and I have already purchased a 5KWh LifePO4 Battery here in Australia at a really reasonable price from Greenbank solar. It's a 24v battery. Now I have decided to make things easy on myself and purchase an all in one inverter so I need to get one that is compatible. This is where I need help. I have been recommended this inverter to work with my battery
Pure sine wave inverter
6.0 KW MPPT
Solar charger of the maximum charging current is 100A
120-500V wide PV input
Can work no battery
Generate power from PV directly to supply load, even without battery
PV to AC efficiency is much higher
SO MY QUESTION IS WILL THIS WORK WITH MY SOLAR ARRAY?
I believe that the inverter needs a minimum voltage of 120 V PV input. So given my solar panels I would need to change these to series connect?
It seems that the high in put voltage requirement may be related to the fact that this inverter can be used without a battery when the sun is out.
AND does this also mean to work well they all need to be fully in the sun most of the day to work at all?
What would be your recommendation? I would like an all in one inverter but perhaps I should put the system together myself. Or just wire the solar panels in series for now as a quick solution. Any input is appreciated.
Cheers,
Sonja
PowMr VM-PLUS-WIFI 3500W Charger/Inverter for sale online | eBay
Find many great new & used options and get the best deals for PowMr VM-PLUS-WIFI 3500W Charger/Inverter at the best online prices at eBay!
www.ebay.com.au
6.0 KW MPPT
Can work no battery
Cheers,
Sonja
