gonediving
Most wind turbines are listed as low speed 500rpm generators. Is this the minimum speed at which they will generate rated power or the max rpm that they should be allowed to turn?
I'm considering bolting a ~5kw permanent magnet generator to my boats diesel engine to recharge my 48v Lifepo4 house bank. All seem to be advertised as low (500rpm) units. Are here models that are rated to ~2000 rpm?
Generally speaking, wind turbine generators seem a cheap and easy way to build a ~5kw DC generator that is happy with variable drive speed. I just have to find a model that has a suitable rpm range.
Thanks
Thanks
