Dem66
I will be building a Lifepo4 Battery Bank for a camper trailer that sits in my driveway all winter in the mountains of Colorado. I researched winterizing the battery and found conflicting information. A video from Battle Born says to charge the battery to at least 14.4 volts and then disconnect the battery. Somewhere else I read to charge the battery to no more than 60-70% and then disconnect it. What is the consensus on what to charge the battery to before disconnecting it?
Also I plan to put on a negative battery cut off switch. Which side of the switch should I wire the BMS? Is it better to have no load on the battery when in storage including the BMS? Or should the BMS be connected to the battery all the time including while in storage?
Thanks,
Dan
Thanks,
Dan
