Hi
HaldorEE can you explain why the isolated version is the correct choice for a towed trailer?
I am setting up such a system now and have been unable to find that answer from Victron.
Thanks,
Mike
In order for fuses and circuit breakers to protect against wiring shorted to the chassis, you have to connect the battery negative to the vehicle chassis. This is the same reason why in AC wiring the white neutral wire is connected to the safety ground.
However, you only want to make this connection at a single place, otherwise some of the return current can flow through chassis ground instead of the negative wire. This is not a great idea since current flow through dissimilar metals can cause corrosion. Plus if the current path is interrupted (by opening a car door for example), this can cause unexpected operation.
In automotive electrical systems, the negative terminal of the battery is connected to chassis ground. When you install a house electrical system that uses alternator charging you don't need to add a connection from the house battery negative to chassis ground, in fact you shouldn't do this unless you use an isolated DC-DC charge controller.
There are two situations where an isolated DC-DC charger makes sense. When adding alternator charging to an existing house electrical system that already has a negative to chassis ground connection. Or in a trailer that must connect the house negative to chassis ground even when connected to the tow electrical system which also has a negative to chassis ground connection.
Systems in a trailer that use alternator charging have to work both when connected to the tow vehicle electrical system and when disconnected. An isolated DC-DC charger controller permits you to ground the trailer system negative independently of the starter battery negative to chassis ground connection.
You can always use an isolated DC-DC charger. The only reason why you wouldn't is because the non-isolated versions are cheaper, and you are installing the house system from scratch and are willing to use the starter system negative to chassis ground connection.
