harriss3
I have an XW Pro 6848 with 60kw of batteries and plan to install a wattnode so that I can charge at night on my EV plan and then cover my loads during peak. The problem is that the batteries won't charge until the voltage drops under the recharge voltage but if I increase this setting it disables the sell function even if the sell voltage is set lower. I tried calling Schneider but they just told me that that wasn't how it was designed to work. They offered that I could use force charge but I can't stay up every night to start force charge at midnight. Basically I would need to wait until my batteries go low enough that sell stops and charging starts however the sell stops before it gets low enough to charge so even that won't work. I'm wondering if there is a way to a scheduled force charge from my computer through the insighthome local IP address or Canbus. I think MODBUS might be an option but the wattnode will be connected to the MODBUS and it is my understanding that only one connection is available.
