fuzzmunky415
I've ordered a battery, and just saw a teardown showing the cells are laser-welded...so I suppose not user-serviceable. I also ordered a 1035+ with the hope of comparing the current state of cells in the pack wrt internal resistance, and to understand how well matched the prefab pack is. Then I thought to myself...self, how do I get an accurate reading when I cannot separate the cells? My first thought was to try my best to access reading from as close to the 'post' as possible, and since the IR meter is sending an A/C khz signal, I would need to access and remove the balance jumper from the BMS. Do I have this correct? Cheers!
