It's Working!!! Sol-Ark 15K, 33.52kW with 67 Panels AC+DC PV, 25kW SOK Batteries - Photo Diary
Holy Export Batman!!!
Hit 28kW PV today. My export limit is 25kW with my utility so, that is about as high as it's going to get with the Sol-Ark before it starts curtailing the output. :(
I guess I never thought my battery wouldn't be full by the time the cloud lens hit. So it would have a place to dump the excess energy. 30.2kW spike today today and it's totally cloudy out as we are expecting snow this afternoon.
Sometimes this just seems to defy logic.
First negative power bill! -$44.94
Something that did not occur to me, my taxes are a negative value too. So hopefully I will never see power bill again, only credits. Then once a year, maybe around April, I'll get the power company to write me a check for the balance.
It's working!!! Amazing to finally get here!
Such a beautiful thing. That's awesome!
Uggg. My natural gas 50 gallon water heater started leaking yesterday and I shut it down and drained it. Ordered a 80 gallon Rheem heat pump water heater yesterday evening. Need to run a 125A sub panel into the basement to support the 30A 240V circuit for the Rheem, 15A circuit for outside for the generator battery tender, and a 20A circuit for my servers. Going to work on my my one line diagram today so I can pull a permit. Probably going to run the 30A wire to go from the generator to the EG4 Chargeverter. Going to be a busy week.
The Rheem water heater will take about a week or so to get here. So we are not going to have hot water during that time. Uggg! :(
Free trial gym membership for their showers?
LOL! Just going to have really bloody cold showers I guess. Might try turning on the gas water heater for 4 hours every 2-3 days and do everything we need during that time then drain it again afterwords. It's leaking into a big drip pan so it's going into a drain. I'll see. A lot will depend on what my wife wants.
No hot water out of the shower but you can boil water on the stove and take warm baths.
Canceled my order this morning from Home Depot for the Rheem 80 gallon heat pump water heater. Learned about some heat pump advances using 120V. So I went down even deeper down the rabbit hole for water heater heat pumps.
After looking at a bunch of brands and reading so many reviews it was causing me to go bug eyed. In the end, I went the 240V 80 gallon Rheem again but added the additional Home Depot warranty for $75. Only downside to the Rheem that I can find is that the Gen5 version is a bit loud. It's going to be in the basement, so most likely it won't be a problem. So that put me a day behind.
This video will start you going down the rabbit hole:
AO Smith reviews showed a bunch of compressor failurs within two years, it was quiet though.
Really hard to find sources to buy the other brands. The LG water heater though seems to be very promising, but it's pretty much not possible to buy. It was also the only one made in China.
Anyway, going to start working on my permit plans now.
Are you AC coupling through the gen input or through the grid? What is the benefit you were looking for in AC coupling?
I am AC coupling through the Gen input. I wanted to add more than 19kW of PV, so I did a mix of DC and AC PV to get me to 33.52kW. If I wanted to just do less than 19kW of PV, I would only use PV on the DC MPPTs.
Got it. I have the same inverter and was wondering about ways to use the gen input/output. Currently my current panel array is only 6k but looking to upgrade to more panels and more batteries.
Just for clarity (I am a noobie) can you get power out of the gen input, and through your regular pv input at the same time? Is the setting gen peak shaving?
The Gen input can be used in several ways, Generator, AC Coupled, out to a smart load panel, etc.
But yea, in my case, the AC coupled PV and DC PV are both operating at the same time. I enabled the AC Coupled on Gen Port setting.
In the manual Grid Peak Shaving with a generator confuses me. It says the generator would be attached to the Grid input and it's talking about and shaving energy used from the Grid. A running generator and the grid can't be connected at to the same input as they both would put out the sine wave and there will be major conflicts and I don't really know what would happen, other then it being potentially very bad.
Finished installing the Heat Pump Hot Water Heater along with a mixing valve about ten days ago. Set the temperature of the 80 gallon Rheem to 150 degrees and the mixing valve to 130 degrees. I have it set on the Energy Saver mode which mostly uses the heat pump unless the temp gets too low and it will kick in the electrical elements, which only occurred the first day when I turned it on. On average I'm using about 3-4 kWh a day.
Everything took longer than I expected. Three days of work to get the sub panel in the basement. Two more days to add the three additional electrical circuits, water heater, computer servers, under deck for the generator trickle charger, and run the 8AWG cable for the generator to go from the garage to the back of the house. A day an a half to get the old water heater out and the new water heater in. Then a few days go get the drain/condensate PVC pipe exactly the way I wanted.
I spent pretty much the weekend putting the basement and garage back together. I picked up the pipe fittings to add the natural gas quick disconnect for generator. I should be able to get that done in the next day or two.
Also had a few 200+ kWh days last week. Totally awesome to see that.
Put the high altitude gasoline carburetor jet in the Firman Tri-Fuel (T07053) generator yesterday, put the oil in it, and ran it off of natural gas for 10 minutes to make sure it worked. Today we had snow and pretty much no solar. Great time to run the generator for the five hours to break it in. Programmed the EG4 Chargeverter for 57 volts and 85 amps and away it went. I was worried about the temperature of the Chargeverter but it barely got warm. On average I was charging the batteries about 10% every hour and covering my house loads during that time. After the five hours the Chargeverter showed it generated 27.5 kWh. The generator is louder than I would like, but whatever. Though my wife really did not like the noise it made. But, it will only be used for emergencies when the grid is down and there is no solar. Going to run the generator every couple of months for a couple of hours to exercise it. I'll change the oil tomorrow and fill it with Mobile 1 5W-30 full synthetic and then next oil change after that will be after running it after a hundred hours.
So the Firman generator is almost an ideal size for single Chargeverter. Got it form Costco so it pretty much has a lifetime warranty. If I was off grid and I needed the generator more than once in a while, I'd probably go with a whole house generator. But for my use, I think the Firman works fine.
@HighTechLab is going to laugh at my small setup. Real men go big!
I also have a little 2000W gasoline inverter generator. Going to pick up the plug ends and make a cable to connect it it up to the Chargeverter.
Grrrrrrr! Got my utility bill today and they reduced what they pay me for generation. The Avoided Cost went from $0.0555 to $0.03778! A reduction of 32%. Yea, not too happy about that. Going to hurt my ROI for sure. Not sure if the Avoided Cost is truly the whole sale rate of electricity for my utility or not. The utility annouced partnering with another solar farm in their last news letter. Wonder what they are paying them.
I was given a little gasoline Smarter Tools AP-2000iQ inverter generator late last year. It is a 2000W surge and 1600W running generator. I changed the oil in it and I made the little adapter cable to hook up to the EG4 Chargeverter. It works fine, but I have to step up the amps over a minute to give it time to adjust to the new load other wise it overloads if I start it much higher than 10A. Right now I start it up on 10A, wait 30 seconds, change it to 15A, wait another 30 seconds, then change it to 20A. Anything much more and it overloads. Only getting 1140W out of it to charge the batteries. Big advantage of it is that it's much quieter than the bigger Firman generator which is expected. It's going to be my stealth generator and it should be able to maintain my house loads and even charge the batteries a bit if I turn of the servers in the basment.
Thinking of ordering a little natural gas conversion git for it. I know it will further reduce what it can ouput. But if I'm out of gasoline, at least I "should" have natural gas to feed it.
