Here's what I used.
Tall, but not nearly as big as a 200A safety switch.
The Square D by Schneider Electric QO 200 Amp Outdoor Circuit Breaker Enclosure includes a two-pole QOM2 frame sizes circuit breakers 100-225 amp capacity for use as an exterior disconnect. This breaker
www.homedepot.com
Well, not all switches are as big as the 600V AC/DC one I was thinking of. This one is halfway reasonable
Siemens offers a wide range of switch products to service the residential, commercial and industrial markets. Safety switches are available in 30-1200 Amp ratings in all enclosure types. The VBII safety
www.homedepot.com
Nice thing about fuses is you might be able to get very fast trip. But maybe not in that form factor?
Consider also just a box with fuses, maybe the really fast "semiconductor" type if desired. You could shut off the main, remove fuses, turn main back on. Fuse holders for class-T and similar are pretty compact. Could mount in a small box.
