kolek
Inventor of the Electron
- Sep 29, 2021
- 467
This is an anti-DIY message specific to DIY batteries, so I apologize, but my message for the masses is, unless you know what you're getting into, consider buying a pre-assembled battery.
Deciding to DIY my solar battery was one of my worst mistakes ever.
I'm still not done yet, and so far the project has wasted about 12 million hours of my time.
Originally I was going to buy fully wired batteries in a box from Amy, but was told the boxes were too big and couldn't be shipped to my country. So stupidly, I figured I could do all the boxes and wiring myself.
Even for pro-level handymen, to do this right, with all the research required, the fixtures and compression and flexible busbars and sizing and building the box and top balancing and the BMS and the fuses and wiring... etc. etc. this is a really big project. For the record, I happen to be a pretty crappy handyman. So maybe for some of you this is a walk-in-the-park.
But my message for the masses is, unless you really really know what you're getting into, buy a pre-assembled battery. For the vast majority of people who are working for a decent wage, when you figure in the cost of your time, a DIY battery doesn't save you anything. I guess if building one of these is your idea of a good time, then go for it. But in my case, I'd rather spend the time doing other things.
/rant
Edited to fix typos
/rant
Edited to fix typos
