oneballjaysocket
Can someone give me some help with calculating what I'd need , as far as panels and battery size, to fully charge a motorcycle with a 10 kwh battery? It has twice the range that I need for my commute, so it won't always need a full charge. But I want to oversize a bit, because I can always find a use for extra electricity. Also, I work from 4 pm to 1 am, so the charging time could be during the first half of the day, from the panels, or after I get home at 1 am , off of battery(ies). It charges in two hours, the specs say.
I live in Ohio, and have good southern exposure.
Let me know if I can provide more relevant info.
Edited for more info:
I have a 6.5kw inverter with mppt charger that accepts utility or generator power, it puts out 48 v, and the manual says it can be used without batteries. It's a SunGold 6500 watt inverter
