Preliminary design, EE but noob solar designer. Looking for clues…
Project: Barn interior / exterior area lighting, maybe about 700W LEDs; maybe some fans in summer, low heat / freeze protection in winter (future expansion for an insulated tack room); and intermittent 115V loads. Off-grid, but potential later to connect (much later). Southern Oregon, dreary winter this year.
Panels: ?
Battery: 24v 8s ?Ah cells LiFeOP
BMS: PB2A16S-20P
Inverter: ?
MPPT: Here’s the deal: the pb2a16s bms can limit overcharging, but is it a mppt charge controller or something more limited? JK website is unclear. Would I be better off with a separate MPPT like a Victron 250-70 or 150-35?
I know the trade-off for cost (don’t buy bigger than you need) but that’s difficult to determine. So here’s kinda what I’m thinking.
3x 500w 48V panels and I’ll be able to get good southern exposure and angle.
8x 260Ah 3.2V cells
3KVA Inverter
Is that enough panel to get me through winter days with lots of cloud cover or will I need additional panel(s)?
I could go with higher Ah batteries for minimal extra cost, but I’m not sure which is better - more storage capacity than charging capacity or vice versa? I’m thinking more charging capacity is better to maximize battery charge. At the same time it would be nice to have a portable fridge out there (for horse meds and stuff) so more battery storage is not a bad thing, just need enough juice to keep it charged. Is it okay to never or only occasionally fully charge the batteries in the winter? It dips into freezing here but it’s usually above the mark during the day.
Enough! I need answers so I can ask better questions.
Panels: ?
BMS: PB2A16S-20P
Inverter: ?
8x 260Ah 3.2V cells
3KVA Inverter
