Lipo4 battery storage
Sik-wit-it
Virginia
I have two 24 volt LiPo4 batteries 100ah each I also have two 12 volt lipo 4 batteries 400ah each I want to tie the two 12v and series which will be 400ah 24v is there anyway I can tie the two 12 volt batteries in series to the two 24 volt batteries to get a total of 600ah even tho the 24v 100ah are less in ah then the two 12v 400ah that will be in series to make 24v will this work.
Two 24v 100ah in parallel to make 200ah tied to the two 12v 400ah in series that will e total of 400ah together the total will be 600ah ???
Yes. 600Ah.
Best option would be to attach each 24V battery to bus bars creating a 3P 24V bank.
VERY important that the two 12V be charged to full individually and preferably again in parallel to ensure they are top balanced.
Once established, you should use a clamp DC ammeter to confirm that the batteries are each operating within spec during high current charges and discharges.
See link #6, section 3.3 for best practices in paralleling batteries.
Yes. 600Ah.
Yes. 600Ah.
So the 24v 100ah batteries won't drain down first being there are less in ah ?
Yes. 600Ah.
Yes. 600Ah.
Correct, as long as the cables feeding the batteries are same resistance, and the arrangement is balance drain.
What do you mean by same resistance
Those appear to be the cheap brass bussbars, very high resistance, and not nearly the amp capability they advertise…
So send me a picture of the ones you think I need.
And I don't think I'm pulling nowhere near 200ampsfrom the batteries at one time tops maybe 20amps
Yes. 600Ah.
Why can't I just tie the batteries together the same way without the busbar?
Put the 12 volts in series and go from positive to positive to negative to negative to each battery and then to the bus bar
One more question would the 24 volt 100 amp hours drain before the 400 amp hours and how low can I set the batteries before charging again I usually go down to 22 to 23 volts before charging again with utility or solar
I'm having a problem picturing this, but if you have 8 cells connected in series (4S in series with 4S), when you connect the individual cells in parallel, that will be a dead short (and there will be sparks, fear and then sadness). Hopefully a video too.
haha, yeah that is worded in an especially frightening manner.
Hello I have one more question before I rearrange my battery so you don't think the 24v 100ah batteries will drain first and shut my inverter off being the other batteries is 400ah I think the 100ah will drain first and shut off unless I set the charge controller not to let the batteries drain that low but then I will be loosing ah from the batteries especially the ones that's 400ah I wouldn't get near close draining them down being they hooked up with the 100ah am I correct?
Batteries in parallel are always at the same voltage. Once capacity drops in battery 1, it's voltage drops, which shifts more of the load to the battery 2 with more capacity because it doesn't have as large a voltage drop. If there is any voltage difference between the batteries, current will flow from the high voltage battery to the low voltage battery. Under load, this will simply be an uneven outflow of current from the batteries, not transfer between them.
The ratio of how they drain may be variable and a little erratic, but you will have 600Ah of usable capacity. Once you get to the lower end of it, you may experience greater voltage drop and may not tolerate heavy loads as you would with a single 600Ah battery.
Warning! LFP batteries are NOT compatible with lipo (NCA or NCM cathode.) They use different voltages and will not have the same OVP and UVP setpoints.
Subject and OP clearly indicate a different intent. Lipo4 suggests a simple typo rather than an intent to run LiPo cells.
Otherwise, I would have whipped out the pedantry too. :p
Thank you
