I’m not running the UI version but have it defined in code at 90% SOC it ‘divided’ to only charge with 20amps. At 95% SOC it sets charging at 5amps. Gives me a good amount of balance time.How do you use slow charging parameters? What are yours?
It seems anything I enter stops charging completely.
What does "divider" mean in this context?View attachment 214555
It must not be working. In the GUI versionI’m not running the UI version but have it defined in code at 90% SOC it ‘divided’ to only charge with 20amps. At 95% SOC it sets charging at 5amps. Gives me a good amount of balance time.
My battery is 200ah and defined in code that way. I need the look at the code in my config but here is the source from git. If I understand this, > 90% SOC 200ah/10=charge at 20a. If > 95% SOC 200ah/20=charge at 10a.It must not be working. In the GUI version
Im charging at 50 amps currently.
if I put in 20 it stops charging
If I put in 2 it stops
if i put in 80 it stops.
If I populate both setpoints with corresponding values, it stops charging
I have tried decimals but it wont save.
No clue over here :!:~
Hmm, Ill try negative numbers
That didnt work either.
Yeah, that makes sense, but it doesnt work in the gui.My battery is 200ah and defined in code that way. I need the look at the code in my config but here is the source from git. If I understand this, > 90% SOC 200ah/10=charge at 20a. If > 95% SOC 200ah/20=charge at 10a.
if (_battCapacity > 0 && _initialBattData){
if(_battSOC > 95)
_chargeCurrentmA = (_battCapacity / 20);
else if(_battSOC > 90)
_chargeCurrentmA = (_battCapacity / 10);
else
_chargeCurrentmA = _maxChargeCurrentmA;
Any feature that you think would suit the software, drop it in here and i'll see.
Added to the feature list is: Multiple probe temp monitors with control of fans forced cooling the inverter and heaters for the batteries.
// otherwise, adjust charge rate depending on batt min temp and SOC
else if (_battTemp < 1)
// no charge if temp < 1 degree
chkCatChange(1);
CAN_SetChargeCurrent(0, "Battery temp < 1 degree");
//writeCriticalErrorLogStr("Warning: Charging stopped as battery temp < 1 degree");
else if (_battTemp <= 10)
if (_battSOC > 90)
// no charge over 90% if < 10 degrees
chkCatChange(2);
CAN_SetChargeCurrent(0, "Battery temp <= 10 degree AND battery SOC > 90%");
else if (_battSOC >= 70)
// if SOC between 70 and 90%; charge at range of 3.5A to 35A = 0.0125C to 0.125C from 1 degree to 10 degrees
// which is less than recommended allowance up to 0.2C at 10 degrees
chkCatChange(3);
CAN_SetChargeCurrent((_maxChargeCurrentmA / 20) * _battTemp, "Battery temp <= 10 degree AND battery SOC between 70% and 90%");
else
// if SOC < 70%; charge at range of 7A to 70A = 0.025C to 0.25C from 1 degree to 10 degrees
// which is less than recommended allowance up to 0.4C at 10 degrees
chkCatChange(4);
CAN_SetChargeCurrent((_maxChargeCurrentmA / 10) * _battTemp, "Battery temp < 10 degree AND battery SOC < 70%");
else
// battery temp within normal range (i.e. > 10 degrees)
This is a reason for the adding of the Temp probes, but the battery temp would only be a feed for the MaxCurrent, the actual current would vary and reduce as battery voltage rises or falls.![]()
I also allow the Solis to "trickle charge" the battery pack up to a pre-defined but configurable max individual cell voltage (3.45V in my case) once the SOC is reported (from the BMS in my case, but from the Smartshunt in yours) as being 100%. This, I found, avoids any drift of the reported SOC the the actual SOC, makes sure a full charge is achieve and gives more balancing time. So what my code does is when it see 100% SOC reported, but cell voltage is below 3.4V, it sends the Solis a 99% SOC CANBus value and a charge rate of just 4A (=batt capacity with a slow charge divider of 70).
LOL... yes... been there, done that... 2A doesn't work!Just to note the Solis has a minimum cut off, so if you go under i think 4a it just stops.
Interesting... maybe that is firmware-related thoughAlso, Solis seems to have a restart of charging min of 96%, so if you hit 100 and then change to 99 it may ignore to charge again.
I think it's following the Pylontech spec, with Pylontech protocol, it says the inverter shouldn't restart charging until under 97%.Interesting... maybe that is firmware-related though. Our Solis has been switching between 99% and 100% SOC every 30 mins or so, all afternoon.
Its something! Thank you!Well, first try of LCD display isn't quite what I had planned. Few tweaks required!
Have you used the new version, and if so, is it working well for you?Its something! Thank you!
I have not yet, but I plan too.Have you used the new version, and if so, is it working well for you?
Am running it "as production", but obviously I also change mine to test new features, so it's currently running master with some changes to the LCD display code - it did have display support in it originally but for the M5 stack devices.So, is V2 ready for primetime, I honestly have not had time to look further into it. I would love to try it out on my EG4 6000xp in the next few weeks.
Random V at the bottom, not sure where that comes from!
But now you don't have to look at my face! it's an improvement.....Few random things...
1) Now I can't spot your threads easily from your smiling face, with the new avatar![]()
Well, probably right but i went with what the AI generated, am happy to receive your contribution......
Yeah it's from the second line, wraps to 4th, it's bizarre in that jumps, the SOC hasn't been at 100% and nothing would have pushed it either, but am going to change it anyway, just toying with the layout.3) I found those LCD screen do a funny wrap-around if you inadvertently write more than 20 chars on one line. So, I'm guessing here, but I suspect the "V" is the V from the end of the SOC / BV line (line 2) when the SOC goes to 100% and the final V gets pushed into character 21 position.
If something goes down it changes to the start up screen to show the problem, but you don't need the IP address really, I implemented MDNS, so you just go to hostname.local and the webpage appears, can send you the code if you want, it's easy.4) And finally, just an idea... I found it useful on my 20 x 4 LCD screen to be able to show more info (like IP address that you have on the flash screen) and, when you get round to it, temperatures etc. So I hooked up a button press that allows the LCD to be cycled around different screens.
@SeaGal Just ordered a Raspberry Pi 5 to do my own emoncms logging, stopped doing it some years ago but decided to do it again, Home Assistant isn't really working well to be a logger with the amount of data am generating.
