Maxout77
I have a Victron Battery Balancer and Vitron MPPT Controller.
The reason for the balancer is I have two 12v 100ah Lifepo4 batteries connected in series. I notice when the batteries start to get to full charge the battery balancer kicks on and then the wattage through the controller drops for a moment then rises back up. This continues over and over again unless I turn off the power coming from the solar panels at which point the balancer seems to balance things out and turns itself back off.
The inverter also seems to lose power for about a second before gaining it back. When this happens and I monitor the voltage the controller is showing for the batteries it jumps up to 30V for a brief moment.
Is this because the balancer is turning on and transferring energy at the same time as the controller providing energy to the battery causing the voltage to jump up? Currently, I have the controller set to the default for 24v lifepo4 that it automatically set itself to which seems to align with the battery factory specs. Should I be lowering the absorption settings perhaps?
