wascalwabbit
So I built a battery from lifepo cells and finally connected everything to the inverter/charger. I used mostly 1/0 cables, except for a longer (30 inch) run to the inverter/charger where I used 2/0 cables. Everything looks good so, far the inverter booted up without problems and the BMS also didn't show any issues. I tested the resistance at the poles of the inverter, and the value that came up was 6 milliohms. I figure that if I have a bad connection somewhere this would show up as high resistance. Am I correct in the assumption, and is 6 milliohms an acceptable number?
thanks!
Dom
thanks!
Dom
