Caflashbob
Wow as i new member i am impressed by the new technology posted here.
I was the first rv dealer to install solar on all my Foretravel coaches used a tiny 32 watt ARCO solar panel. 1987.
When i redid my current 97 U320 Unicoach i hesitated starting 10 years ago and finishing a year ago about using li-ion but the available Northstar batteries were $6k each.
So i went with the currently available best tech from then until now. For my crazy idea of retaining the true four weather coach build from Foretravel i installed 3 new east-Penn (mk) gel 8d batteries.
Replaced the heart freedom non sine wave inverter/charger with a magnum energy MS 2812 with an added Battery temp monitor add on.
Then a ME-ARC control panel and a Magnum pt-100 solar controller and a ME-AGS networked auto gen start.
I replaced the 4 button HVAC controller with newer Dometic 10 button wall mount thermostat and replaced the Dometic heat strip ducted roof airs circuit board to the newer generation one to network with the auto gen start and to fullly integrate fully automatic dual setback HVAC and gen start as needed.
Setup will auto start the HVAC setup from various temp sensors for both heat and cold and battery charge conditions as needed. I have an aqua hot system in the old coach.
Added 3 lg neon 365 watt solar panels on the roof feeding at 42 volts off the roof for safety into a midnight solar junction box. I only used 3 out of the 6 available circuits.
To keep the red-top AGM chassis batteries always charged i add a Blue-seas ACR 500amp magnetically latched battery combiner. Either bank receives a charge it auto connects the banks. Either bank discharges it auto disconnects the banks.
With the Magnum and the batter temp sensor the system auto adjusts the battery charging voltage to be the correct amount per the temp at the batteries.
I have been rving long ago at way below zero and was a colorado river rat at 120 degrees. Li-ion currently will not work at either extreme.
10k Diesel gen still has glow plugs. 25 years old. The ME-AGS is the only unit that can be set to run the glow plugs for 25 seconds then start. Auto repeat 3 times if no start.
The Power Trace 100 can take 6000 watts and 240 volts and up to 100 Amps and is a large heavy duty solar controller with dual cooling fans and extensive temp monitoring internally as does the MS-2812. Victron was 2400 watts when i was putting the system together and a 40 pound single transformer unit in their Molotov pass II units. The MS- 2812 is a 2800 watt continuous output inverter/ charger with dual transformer and weighs 55 pounds from the heavier build.
Older Victrons were dual transformer and 90% efficient also. They changed to a single smaller transformer for their 93% efficiency.
At least this was true when I built this. Looks still to be true.
Mounting the MS-2812 vertically on a large storage compartment wall gives it enough air volume to not derate in super hot weather as quickly.
BTW as far as I know Victron are not made in Netherlands. Engineering staff is there 35 people. Units were made then in India. Original Victrons were not ul listed. They are now.
Like I said i went with old tech even though its much more expensive to retain the all weather auto HVAC and charging system.
Most rvs are not made for river hot or below zero so those needs would be a lot easier. My roof ac’s have heat stripes in them not heat pumps. Will work below freezing.
