WOLF-GANG
I have got a new Growatt SPH 4600 which is a hybrid inverter. Right now I do not have battery cause it will arrive later.
So I wanted to use it meanwhile as a pure grid converter but the only description I have found sounds a bit weird to me cause I do not know aht the second paragraph means or in particular "you can also float BAT(tery) terminal"
Does that mean I have to connect the + and - terminal on the inverter like a bridge?
They have no graphic that would show that . I have used the translator too to find another meaning of float in this context.
Right now it does not work and this sentence is the only one about using the inverter without a battery in the whole manual.
Currently it feels like I have to connect plus and minus terminal cause otherwise they would not mention the BAT Terminal.
Hope someone can explaint to me what might be meant. THANKS A LOT
![1702522575873.png 1702522575873.png](https://diysolarforum.com/data/attachments/182/182803-7a51491ef66b376957e799cee9ba0269.jpg)
