I have a 200 amp main in the house. Busbar is rated for 200.
100 amp subpanel in detached garage 100 ft away.
12.8kw array and eg4 18kwpv on order+ 1 eg4 wall battery
I see alot on youtube that people attach the inverter BETWEEN the meter and main. I cant do this unfortunately cause its such a far difficult run.
I want to do a grid tie system with one eg4 wall battery as well.
My question is this:
Eg4 inverter has a grid terminal and load terminal. Would I just not use the grid terminals at all?
So just connect into subpanel through a 50 amp breaker to the load side of inverter for backfeeding garage and house?
Or should I run the sub panel feeders into the [Grid] terminals, then put [load] into the mainbreaker on the sub panel?
(and I would obviously follow the 120% rule by Derating the 200 amp and 100 amp sub.)
My other question is, when sending power to the grid, how could that be monitored since id be sending power through 2 panels with household load before it even reaches meter.
Thanks in advance Im learning and reading as much as I can
