400bird
Solar Wizard
Thanks to @istl I made new leads and have a battery balancing and making real progress, where this same M12 2.0 Ah battery was trying to balance through those 1kΩ resistors.
The downside is that it requires removing the outer shell of the battery.
If you just want to measure the cell voltages, all are exposed (and labeled) on the connections.
![1698183414461.png 1698183414461.png](https://diysolarforum.com/data/attachments/173/173968-d41151fe9e865d7f58780705555d4ca8.jpg)
The case disassembles pretty easy and there are a few different styles, I'm sure Google can help it isn't obvious on your pack.
There are a few different circuit boards as you can see in post 21.
Anyways, here's my connections.
![1698183664408.png 1698183664408.png](https://diysolarforum.com/data/attachments/173/173969-a8cb2f6b9dab208c0cbc2aa85863f95d.jpg)
Well, in the 10 minutes I have been typing this and getting pics, the imbalance went from 120 mV down to 5 mV
Once I get this pack balanced, I'll capacity test another pack before and after balancing to see the improvement.
When this impact released there was nothing like it, high torque for the compact size. This is why I made the swap, now there is plenty of competion, but I still like it.
www.milwaukeetool.com
Yeah, I had a different brand tool before switching to Milwaukee, but Milwaukee has just so many tool options for specialty tools and the M12 line is inexpensive and quite capable. I've been happy since swapping to Milwaukee about 5 years ago.I'm the oddball with a lot of Ryobi tools. My oldest being my 1/2" Impact, it's been through about 5 or 6 years of daily mechanic work, doing tire rotations etc, and my oldest battery being a 4ah. Both the battery and impact are 12 years old now. The battery shows signs of aging, as the tools aren't as snappy compared with a newer battery, and it's average run time is shorter, but damnit a 12 year old battery is really impressive!
I would like to swap over to Milwaukee, but its hard to change over when I already have THIS many Ryobi tools/batteries.
![www.milwaukeetool.com](https://www.milwaukeetool.com/-/media/Products/Power-Tools/Cordless/Impacts-and-Fastening/2554-20_1.webp?mw=520&hash=361AFA08FC2F1624EA2E3C56E6F131AE)
M12 FUEL Stubby 3/8" Impact Wrench | Milwaukee Tool
The 3/8" compact impact wrench is 5.1" in length, features 250 ft-lb of breakaway torque, and 4-mode drive control.
![www.milwaukeetool.com](https://www.milwaukeetool.com/img/Foundation/Theming/MilwaukeeTool/global/favicon-16.png)
