400bird
Solar Wizard
I've got about 7 Milwaukee M12 batteries. This morning, one 6.0ah battery failed to charge and the charger started blinking alternating red and green LEDs. The symbol on the charger reminds me of a broken heart, but a battery instead of a heart. You can see the led key on the charger below.
I decided to get some voltage readings and found a 0.7 volt delta between the cells.
C1 = 3.7 volts
C2 = 3.0 volts
C3 = 3.65 volts
Well, I've got a iCharger X8, I can fix that!
Then I realized I also have an M12 charger that I never use. So ummm, tada!?
Ugh, that pic sucks, but you get the point. Balance charger bodged into a real Milwaukee socket. The Milwaukee charger still has the 120vac plug, so it should work, but here it isn't plugged into the wall and is mostly just providing a connection point for the balance charger.
That first pack balanced nice and slow over a few hours while I was doing something else. I unplugged it before it finished to go make dinner.
After dinner, I decided to check the balance on all the other packs.
And I think this was the best pack. Guess what's going to be sitting on the table in the office balancing cells all day tomorrow?
Anyways, it sure does seem like Milwaukee M12 batteries don't do any cell balancing.
Just out of curiosity, I opened a single M18 battery, the cells were 3.886-3.889 volts, so a much better BMS in the M18.
C1 = 3.7 volts
C2 = 3.0 volts
C3 = 3.65 volts
