robbob2112
Doing more research, mosty harmless
My first 2000w inverter came with 2 cables. One was CCA and the other was copper. I only used them for a couple hours to test the inverter and verify it wasn't DOA and when I disconnected the cables the CCA end was black and clearly overheated. Since then anytime I run across a CCA cable here I just toss it in the trash/metal recycle.
