ScrotpusGobbleBottom
Corn Pop was a bad dude.
I didnt say there was anything wrong with that. More likely OP fixed the problem already.Oh Noes! Someone walked away from their computer for hours and hours!
Should we call an ambulance? The OP could be suffering from AED (acute electronic deprivation)? AED has to be taken very seriously! In teenagers it can be fatal!Oh Noes! Someone walked away from their computer for hours and hours!
Still waiting for usage results. It's been too hot to cook inside since I got the monitoring setup.What does it use when it's running?
If all else fails, I will try that.You might swap CT's with a another load and see if the problem follows the CT or the behavior stays the same.
I'll do some visual checks tonight and then unplug it to see if it keeps using power.That looks like an oven lighting element? This is a gas stove? I might guess that lighter element is randomly turning on without any gas flowing? Might be a bug in the computer chip, or something has gotten corrupted? You might try opening the oven door when the oven appears to be running and look for a dull-red glow from the bottom of the oven.
You might try unplugging the stove overnight, and then reboot the stove's chip the next morning. If a clean copy of the firmware is running, maybe this issue will go away.
I'll get right on thatIf you want to verify it's a burner, and don't have time to watch it all day, just leave something flammable on top of them.. it will be hard to miss.![]()
Agghhh people have jobs!!! :DOh Noes! Someone walked away from their computer for hours and hours!
Work provides plenty of electronic stimulation even if not on the solar forums.Should we call an ambulance? The OP could be suffering from AED (acute electronic deprivation)? AED has to be taken very seriously! In teenagers it can be fatal!
Thanks for all of the responses everyone. This is an old fashioned electric. No induction, no gas. It's a GE J BP23D R1WW.
That would work, or even a regular camera if you can time lapse either of them. Gotta catch it in the act.. should be able to see them briefly light up red a bit even on a non infrared camera if it's really using 500-600 watts for 30-60 minutes.Or setup an infrared camera on the thing and see if anything gets hot...
I'll try this later tonight. Thanks!That probably has easily removed burners/coils. Remove the coils from the top of it overnight, when you aren't using it anyway.. see if it goes away. If it does, then it's probably the infinite switches wearing out. Then just do it one burner at a time overnight until you find the culprit.
GE ?I have a stove/oven combo. I recently installed the Emporia energy monitoring system and it shows that my oven is always using power. I know the clock is on, but half a kWh seems a little excessive and I would think it would be flat. Does this seem normal? What is causing these peaks (We aren't using the stove at 3AM!)?View attachment 226294
Gotta laugh at the junk being sold these days under the pretense of modern technology, we have a smeg propane stove, runs off a single D cell think I've changed it once in 8 years.The first oven/range we bought for our off-grid house was a bust. I told her it had to be gas, convertible to propane. She got one of the newer Samsung units. 400-600w glow plug igniter, always on. Convection fans, always on, etc etc. Kill-a-watt showed oven used 2200w. A gas oven. Sold it. Bought a Unique brand propane stove. No clock, no cord, no electricity.
Yep, the Unique also uses a D battery for ignition. Love it. The Samsung was super fancy with fancy buttons, lights, even music! FFS!!Gotta laugh at the junk being sold these days under the pretense of modern technology, we have a smeg propane stove, runs off a single D cell think I've changed it once in 8 years.
haha my sister in law has a induction hob that tells you about its status "cooking" "you have ten minutes till finished" "your food is done" she told us it broke ,we asked what was wrong does it not heat up anymore and she told us no it works fine but it stopped talking........Yep, the Unique also uses a D battery for ignition. Love it. The Samsung was super fancy with fancy buttons, lights, even music! FFS!!
It would likely have to be a bug in the firmware rather than false readings from the CT, as I said before as far as I'm aware CT interference tends to be big sporadic spikes or that's what I've seen on the 20 or so I have fitted around my farm.I was watching the app last night before doing any troubleshooting and I'm wondering if it's the emporia system. If I switch to hourly it says I haven't used any power since Monday. But if I switch to minute it says I'm using power intermittently, it the graph is showing zeros.
The CT is closed, facing the right direction. It's physically touching the other wire of the other leg. Would that matter?
View attachment 226489View attachment 226490
0.5W.. It's practically zero, CT can't even measure something that low (0.002A).But if I switch to minute it says I'm using power intermittently
So it's weird, ever since I noticed the issue and started messing with it, the spikes went away. I'm wondering if it's a broken part on the oven that is - currently - not shorting since I physically moved the oven and lifted the top.Be interesting to look at the raw data from the CT clamps to see what it is seeing.
To OP, does the system have the option to download a csv file? If so can you upload it?
