cs1234
Solar Wizard
- May 9, 2022
- 2,883
Growatt SPH 10000TL-HU-US 10.0KW Hybrid Inverter | 15000W PV Input| 10000W Output | 120V/240V Split Phase | Compatible with Growatt AXE LV Battery and Lead-acid Battery
Growatt SPH 10000TL-HU-US 10KW hybrid inverter supports split phase output 120/240Vac, configurable battery charging current/voltage based, and AC/Solar/Generator charger priority by touch screen setting. It is compatible with grid voltage or generator power. When AC power is lost it will...www.self2solar.com
About 1/3 the price of the solark "15k"
@Will Prowse You need to review these things already, so they sell out. Then we won't hear about them as much from @1201 .
