andydarwin
I am using 11000VA techfine Inverter.. I saw when the Output (Load) is 2.35KVA and 2.29Kw
and the Battery discharging current 52A and Battery Voltage 51.9V..
calculating the output i find the efficiency is only about 85%.
is it normal (good ) ? or it is a bad Inverter efficiency ??
