25.6v - 200A (5kw x 2 parallel, there is a mistake in the specs)
This breaker is probably not DC rated, but every server rack battery has one of those non dc rated stuff
Found this for the breaker
Should I put a 200A T class fuse at the cable going to the inverter?
MRBF 200A at the terminal goingong to the inverter?
150A MRBF at both positive terminals?
(I need a 200A fuse anyway to the inverter)
I prefer MRBF in general, I like how easy they are to use, less connections less resistance less crimping
I don't know![Frown :( :(](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
![IMG_20240416_164816.jpg IMG_20240416_164816.jpg](https://diysolarforum.com/data/attachments/228/228735-c08283deb07ec04dc3b7ddb66d085221.jpg)
![IMG_20240702_160516.jpg IMG_20240702_160516.jpg](https://diysolarforum.com/data/attachments/228/228736-9deababa530a2c08452ece7b5419a558.jpg)
![IMG_20240404_165241.jpg IMG_20240404_165241.jpg](https://diysolarforum.com/data/attachments/228/228737-f53ec07d68aeb39dad3dffdf25ef5521.jpg)
I don't know
