Did I mention Rural. Closest town of 20,000 with a United Rent all is 20 miles away - and they don't rent trenchers. Next largest town is over 100 miles away, a town of 250,000 which probably would. Think I try the spade on my tractor - its less than an all day rental would be and I'll own it afterwards.
Really appreciate everyone's feedback
Shovel. Seriously. I buried ~200' of 2/2/4 urd ~24" deep from the shop to the deck roof. If anyone here has ever operated a Mexican dragline, you know how hard it is to dig through hard clay dirt. The trick is wait till there is some moisture in the dirt, and to
keep plenty of cool refreshments handy.
Good, or bad thing about MO, no statewide adoption of NEC. 24" is a sefety issue, it's below most burrowing animals, including man w/shovel ... usually.
If you use plain white schedule40 pvc (considerably cheaper than gray pvd) use marker tape higher up in the trench do delineate it from a common water carrying pipe. It could save someone from serious injury later. Like mentioned earlier, use the largest diameter pipe you can afford. Trust me, it comes in handy later.
Thinking out loud. Since you are here, you are most likely someone that likes to diy things. Also indicates you will more than likely be upgradeing at some future date. mppt controllers are tending to go the way of higher voltages and that's great for saving on copper. I would run thhn inside conduit as it's made for pulling, pv wire is not, add a ground run with those wires (as mentioned earlier, many AIO have some ac riding the pv inputs), and run extra wires if there might be room to add more panels to the array at a later date, because ... you have the diy bug and if more panels will fit, it will keep bugging you till more panels find their way up there.
