Bananaman321
⚡solar idiot ⚡
Check your meters DC scale to make sure that your combined series string VOC falls in the parametersI'm making up 7 panel stings. I've come across one that's doing something I'm totally baffled about.
I can measure voltage when it's not connected to anything but if I connect it in series with just one other panel, then it outputs zero voltage.
All I can think of is there is something in the small black box the cables are coming from that disables the output when the voltage goes higher than the panel can output on its own?
Stumped.
![20240805_223958.jpg 20240805_223958.jpg](https://diysolarforum.com/data/attachments/234/234268-660743c154eb3d1809ae3d1454539524.jpg)
