Here is the Moes/Spartan ATS(Auto Transfer Switch) video that Will reviewed and explained it in better details. The OP was asking why the high load draw, in this case the AC 12K BTU window type air conditioner would caused the battery voltage to drop and caused the ATS relay to switch over to the grid power. We were just speculating and try to see if it could be set to a low voltage drop for the auto switch over to grid power so it won't switch to grid as often. Also, assuming if the ATS constantly toggle between battery inverter, this will prolong the battery or inverter, because those in-rush current draw will cause issues for them later down the line. So, the ATS could potentially saving those components by using the grid in high load when the AC compressor kicks in. Hope that make sense.
