adriansantos
- Apr 28, 2020
- 45
Hi, can anyone comment on my planned project.
So i have a total 1,200 watts panel which supplies my current 1Kw Grid tie system. I want to add another MPPT in parallel with my Grid Tie, both getting power from the Solar Panel. Will this work?
My thoughts:
- both grid tie and mppt will get >60v and should function at the same time but power will be divided to the 2 system
- I was thinking if the battery will be charging at 20amps it will be at 80-90% charge in 4 hours and BMS should cut the supply making the Grid tie the sole leecher from the panel
- The offgrid will only function at night to supply some garden lights and wont be using 80amps, maybe just 40 amps max in 10 hours, so maybe it will be just take 2 hours to reached 90% charge capacity.
